imx8m mini evk: no output on MIPI-HDMI after kernel boots-up
harshamedu
I the MIPI-HDMI output works fine during uboot. Once it starts loading kernel, the display vanishes.
I am attaching the uboot setting. Please let me know hat's wrong with the settings.
 IMX8M Mini EVK MIPI-HDMI Display
harshamedu
   It is imx8mm evk board. It was based on build 4.14.78. The person who built the package doesn't work with us. I loaded pre-built image of latest version 5.15.5 (imx-image-full-imx8mmevk.wic). The display MIPI-DSI to HDMI works fine. I have attached the uboot and kernel messages in my previous post. Is it possible to figure out from that what is happening ?
harshamedu
I couldn't find pre-built image with display enabled for linux version 4.14.78 Do you have ?
joanxie
you can download the image from official website, the default images include this
"https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat..."
joanxie
did you use imx8mm evk board or customized board? what did you change in the source code? did you use nxp pre-built images or your own built image? pls share with me more detailed information
