imx8MQ: How to flash image for initramfs
1,241 次查看
kinjalGediya
Hi NXP,
I am trying to doing full roofs encryption and for that I have read that document "The document "Root filesystem encryption using DM-Crypt"
In above document, the method for encrypting rootfs (full disk encryption) is using initializing initramfs.
I have enable kernel configuration which are given in above document. After compiling and building above configuration; I have cpio.gz Image.
My question is
i.) How to flash cpio.gz file or How to use *.cpio.gz Image for my iMX8MQ nxp board.
标记 (1)
1 回复
1,203 次查看
Rita_Wang
Which version BSP are you using? For downloading you can use the uuu tool.
