imx8: qtwebengine do_compile error
vsuneja63
Thanks!
I am trying to build qtwebengine in yocto images for i.MX8MQ evk target. its failing in do_compile, attaching the error log file for the same. Its blocking for me, any suggestion on this will be highly appreciated.
Hi Vipul
one can try to follow sect.5.6.6 Qt 5 and QtWebEngine browsers  i.MX Yocto Project User’s Guide​  or
http://ess-wiki.advantech.com.tw/view/IoTGateway/BSP/Linux/iMX8/Yocto_LBV9_User_Guide#To_add_QtWebEn...
vsuneja63
Thanks for reply!
I already have IMAGE_INSTALL_append += "packagegroup-qt5-webengine" in local.conf but do_compile error is still there.
