imx6ul gpio
imx6ul gpio
1,155件の閲覧回数
ninghongxie
If imx6ul uses gpio_set_value function to simulate a certain time sequence, it will cause CPU occupancy rate to be particularly high. If I operate the GPIO DR register myself, this will not happen.
3 返答(返信)
822件の閲覧回数
Hi ninghong
you are right, also one can look at below link for suggestions how to increase speed
https://community.nxp.com/message/841330?commentID=841330#comment-841330
822件の閲覧回数
ninghongxie
Hi igorpadykov
    Thank you for your advice, but I think this is a different case. Now I am driven by linux, frequently calling the interface gpio_set_value will cause the whole Linux system to become very slow, and even affect other functions.
822件の閲覧回数
ninghongxie
Can imx6 GPIO set registers that specify a bit change? So I can use registers to control my driver directly. Not considering mutex
