Hi, I reproduce the following errors:
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
caam 2100000.caam: job rings = 2, qi = 0
alg: No test for authencesn(hmac(md5),ecb(cipher_null)) (authencesn-hmac-md5-ecb-cipher_null-caam)
alg: No test for authencesn(hmac(sha1),ecb(cipher_null)) (authencesn-hmac-sha1-ecb-cipher_null-caam)
alg: No test for authenc(hmac(sha224),ecb(cipher_null)) (authenc-hmac-sha224-ecb-cipher_null-caam)
alg: No test for authencesn(hmac(sha224),ecb(cipher_null)) (authencesn-hmac-sha224-ecb-cipher_null-caam)
alg: No test for authenc(hmac(sha256),ecb(cipher_null)) (authenc-hmac-sha256-ecb-cipher_null-caam)
alg: No test for authencesn(hmac(sha256),ecb(cipher_null)) (authencesn-hmac-sha256-ecb-cipher_null-caam)
alg: No test for authenc(hmac(md5),cbc(aes)) (authenc-hmac-md5-cbc-aes-caam)
alg: No test for authencesn(hmac(md5),cbc(aes)) (authencesn-hmac-md5-cbc-aes-caam)
alg: No test for authencesn(hmac(sha1),cbc(aes)) (authencesn-hmac-sha1-cbc-aes-caam)
alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-caam)
alg: No test for authencesn(hmac(sha224),cbc(aes)) (authencesn-hmac-sha224-cbc-aes-caam)
alg: No test for authencesn(hmac(sha256),cbc(aes)) (authencesn-hmac-sha256-cbc-aes-caam)
alg: No test for authenc(hmac(md5),cbc(des3_ede)) (authenc-hmac-md5-cbc-des3_ede-caam)
alg: No test for authencesn(hmac(md5),cbc(des3_ede)) (authencesn-hmac-md5-cbc-des3_ede-caam)
alg: No test for authencesn(hmac(sha1),cbc(des3_ede)) (authencesn-hmac-sha1-cbc-des3_ede-caam)
alg: No test for authencesn(hmac(sha224),cbc(des3_ede)) (authencesn-hmac-sha224-cbc-des3_ede-caam)
alg: No test for authencesn(hmac(sha256),cbc(des3_ede)) (authencesn-hmac-sha256-cbc-des3_ede-caam)
alg: No test for authenc(hmac(md5),cbc(des)) (authenc-hmac-md5-cbc-des-caam)
alg: No test for authencesn(hmac(md5),cbc(des)) (authencesn-hmac-md5-cbc-des-caam)
alg: No test for authencesn(hmac(sha1),cbc(des)) (authencesn-hmac-sha1-cbc-des-caam)
alg: No test for authencesn(hmac(sha224),cbc(des)) (authencesn-hmac-sha224-cbc-des-caam)
alg: No test for authencesn(hmac(sha256),cbc(des)) (authencesn-hmac-sha256-cbc-des-caam)
alg: No test for authenc(hmac(md5),rfc3686(ctr(aes))) (authenc-hmac-md5-rfc3686-ctr-aes-caam)
alg: No test for authencesn(hmac(md5),rfc3686(ctr(aes))) (authencesn-hmac-md5-rfc3686-ctr-aes-caam)
alg: No test for authenc(hmac(sha1),rfc3686(ctr(aes))) (authenc-hmac-sha1-rfc3686-ctr-aes-caam)
alg: No test for authencesn(hmac(sha1),rfc3686(ctr(aes))) (authencesn-hmac-sha1-rfc3686-ctr-aes-caam)
alg: No test for authenc(hmac(sha224),rfc3686(ctr(aes))) (authenc-hmac-sha224-rfc3686-ctr-aes-caam)
alg: No test for authencesn(hmac(sha224),rfc3686(ctr(aes))) (authencesn-hmac-sha224-rfc3686-ctr-aes-caam)
alg: No test for authenc(hmac(sha256),rfc3686(ctr(aes))) (authenc-hmac-sha256-rfc3686-ctr-aes-caam)
alg: No test for authencesn(hmac(sha256),rfc3686(ctr(aes))) (authencesn-hmac-sha256-rfc3686-ctr-aes-caam)
caam_jr 2101000.jr0: 20000b11: CCB: desc idx 11: AES: Mode error.
alg: aead: encryption failed on test 1 for rfc4106-gcm-aes-caam: ret=-536873745
alg: No test for rfc4543(gcm(aes)) (rfc4543-gcm-aes-caam)
caam_jr 2101000.jr0: 20000c11: CCB: desc idx 12: AES: Mode error.
alg: aead: encryption failed on test 1 for gcm-aes-caam: ret=-536874001
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
1) Is there a fix for those algorithms? rfc4106-gcm-aes-caam,, gcm-aes-caam
2) Can they be disabled?
Solved! Go to Solution.
AES GSM is not mentioned in the Security Reference Manual ; this means no support.
~Yuri.
AES GSM isn't supported in HW.
Yuri
Hi Yuri,
thanks for your quick answer.
Is this limitation documented somewhere in the Security Reference Manual?
Is it related to some CAAM block hardware version that I can check in some register?
Thanks.
~Yuri.
