imx6UL evk with kernel 4.1
matt67
Hello all,
I'm testing the imx6UL evk with yocto and I'm wondering if it is easy to change the kernel provider to build 4.1 kernel.
Currently with jethro, the machine conf of imx6UL evk uses the linux-imx (which is 3.14) and I would like to switch to 4.1 kernel.
What do you think about that ? and what's the easiest way to do it (changing virtual/kernel provider to linux-flsc) ?
Matt
Labels (2)
Tags (3)
qinghuazhu
Now you can download new version yocto from http://freescale.github.io/
matt67
Hello Fabio,
Thanks for your support, I created a custom recipes with this version of the kernel and it worked !
yichen
Hello Matt,
I have the same problem
Do you change setting like
repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
I use these setting
but my kernel is 3.0.35
matt67
Hey,
Here is the the content of my manifest.xml
<?xml version="1.0" encoding="UTF-8"?>
<manifest>
  <default sync-j="2"/>
  <remote fetch="git://git.freescale.com/imx" name="fsl-release" />
  <remote fetch="git://git.yoctoproject.org" name="yocto"/>
  <remote fetch="git://github.com/Freescale" name="freescale"/>
  <remote fetch="git://git.openembedded.org" name="oe"/>
  <remote fetch="git://github.com/OSSystems" name="OSSystems"/>
  <remote fetch="git://github.com/meta-qt5"  name="QT5"/>
  <project remote="yocto" revision="dd0ba9ea4a11ab15348d4fe3574e4b28784db82f" name="poky" path="sources/poky"/>
  <project remote="yocto" revision="35b8b9bd9863de208ab60e33b55f10ee43e2619b" name="meta-fsl-arm" path="sources/meta-fsl-arm"/>
  <project remote="oe" revision="ad6133a2e95f4b83b6b3ea413598e2cd5fb3fd90" name="meta-openembedded" path="sources/meta-openembedded"/>
  <project remote="freescale" revision="3a9c59399dbcf4790578125f016c6e86aff43367" name="fsl-community-bsp-base" path="sources/base">
        <copyfile dest="README" src="README"/>
        <copyfile dest="setup-environment" src="setup-environment"/>
  </project>
  <project remote="freescale" revision="e200df91b70da254461c59082ddd5db0a3c415a2" name="meta-fsl-arm-extra" path="sources/meta-fsl-arm-extra"/>
  <project remote="freescale" revision="2231e946e7a94d096394f2b2477e8184c9bbde7b" name="meta-fsl-demos" path="sources/meta-fsl-demos"/>
  <project remote="OSSystems" revision="b6d46d69a261fe6bd7c1e9811dc2a9bbd0b79aeb" name="meta-browser" path="sources/meta-browser" />
  <project remote="QT5" revision="d5536e34ec985c82b621448ab4325e5cbba38560" name="meta-qt5" path="sources/meta-qt5" />
  <project remote="fsl-release" name="meta-fsl-bsp-release" path="sources/meta-fsl-bsp-release" revision="jethro_4.1.15-1.0.0_ga" >
     <copyfile src="imx/tools/fsl-setup-release.sh" dest="fsl-setup-release.sh"/>
  </project>
</manifest>
You better should use a new repo like I did with imx-4.1.15-1.0.0_ga.
But the way to change the kernel provider also worked for me.
yichen
Hi Matt
Find out my problem was based on my target board.
It can not boot from sd card
Thanks for your help!
matt67
Good to read that you find what was the issue :smileywink:
yichen
@@Hi Matt!
Thanks for your reply.
<manifest>
  </project>
     <copyfile src="imx/README" dest="README-IMXBSP"/>
  </project>
</manifest>
yichen
Hi Matt
We have the same manifest.xml.
But I don't know why I use uname -a command shows up like these?
Yuri
Pleae try using clean build (separate directory) for the BSP.
Yuri
yichen
Hi Yuri,
I don't know how to use clean build as you said.
Yuri
  To buid Your system, please follow "Freescale_Yocto_Project_User's_Guide.pdf",
section 3 (Host Setup) and 4 (Yocto Project Setup), assuming there is no "fsl-release-bsp"
directory on Your home folder.
Yuri.
fabio_estevam
gusarambula
Thank you, Fabio!
