imx28 i2c timing issue with optimization flag
1,261 次查看
shashikanthirem
Hi All,
I am using i2c send and receive written local i2c function call, which am seeing a I2C querry success and perfectly when I enable optimization(-O0) debug symbols, but does not works(NACK) when i remove the above (-O0)  compiler from the Makefie.
Any suggestion would be helpful
using
linux 2.635.3, LTIB
标签 (2)
标记 (1)
1,116 次查看
shashikanthirem
1,116 次查看
Hi shashikant
one can look at attached documentation about new ltib toolchain
and test if this helps.
1,116 次查看
shashikanthirem
i cannot do as of now..
