iMxRT1021 hardfault in IAR C++ library
ChengGu
To whom it may concern,
 I am using iMxRT1021 dev board, my IDE is IAR, my project use many C++ object such as map etc. sometime, my code get hardfault while running in these IAR C++ library codes, or my map objects are crashed in the middle. could this relate with iMxRT cache setting? any suggestion on how to debug such issue? thanks a lot.
Best
Gu
Labels (2)
jeremyzhou
Firstly, I'd like to know whether you locate the code line that invokes the hardfault interrupt. next, I was wondering if you can introduce these C++ libraries briefly.
TIC
