iMX8ULP - change u-boot serial console from UART5 to UART4
fTL
Hello to all of you!
We would like to change the default serial console from UART5 to UART4. It is a custom board but very similar to imx8ulp-evk.
I changed several thing in that direction:
imx8ulp-evk.dts (lpuart5 -> lpuart4 and pin control)
imx8ulp-evk-u-boot.dtsi (lpuart5 -> lpuart4)
u-boot - .\include\configs\imx8ulp_evk.h (ttyLP1->ttyLP0)
layer - \meta-freescale\conf\machine\include\imx8ulp-evk.inc (SERIAL_CONSOLES = "115200;ttyLP1" -> SERIAL_CONSOLES = "115200;ttyLP0")
imx-atf - \imx-atf\plat\imx\imx8ulp\include\platform_def.h (#define IMX_LPUART_BASE IMX_LPUART5_BASE -> #define IMX_LPUART_BASE IMX_LPUART4_BASE)
\conf\local.conf - ATF_BOOT_UART_BASE = "0x29390000"
I have got 13%2:1>Fail HID(W):LIBUSB_ERROR_PIPE(8.647s) during uuu -v SDPS: boot -scanterm -f core-image-minimal-imx8ulp-lpddr4-evk.wic.zst/* -scanlimited 0x800000
What am I missing?
Alex
fTL
**The Solution Unveiled!**
No amount of forehead-flattening frustration will solve this task, save for relentless digging and perhaps a curse or two per minute...
Regardless of your modifications in the device tree(s), if the PCC LPUART4 Register (PCC_LPUART4) isn't properly configured, any attempt to write to LPUART4 will throw an exception. This is why `uuu` halts with a LIBUSB_ERROR_PIPE, essentially a STALL event indicating no response from the other end.
BTW I enabled both UART4 and UART5 in the u-boot device tree.
With invaluable help from a knowledgeable friend (thankfully, such expertise still exists), we discovered that attempting to read from one of LPUART4's registers (`__raw_readl(0x29390010);`) in the Secondary Program Loader (SPL), while UART5 was set as the default serial console, resulted in an exception, stalling `uuu`. The issue was resolved by enabling the clock source for LPUART4 with `__raw_writel(0xd2000000, 0x292D00E4);`.
Although we thought the issue was pinpointed, our investigation continued.
The clock initialization within `lpuart_serial_probe` (located in `serial_lpuart.c` for the iMX8ULP serial driver) should work when CONFIG_CLK=y, but it didn't or I missed something ..
Our digging led us down the clock configuration path where we stumbled upon what might as well have been a magic number:
- In `/arch/arm/include/asm/arch-imx8ulp/imx-regs.h`, line 50:
```c
#define LPUART_BASE LPUART5_RBASE
- Similarly, this was mirrored in the ATF firmware:
`/plat/imx/imx8ulp/include/platform_def.h`, line 72:
```c
To fully resolve this, you must update the device trees (both the board `.dts` and `*-u-boot.dtsi` files), and modify these two files to reflect the chosen LPUART. Also, ensure to review SPL-related files for any IO conflicts with your selected LPUART.
That's the crux of it.
- Alex
ajhoneybell
Hi, I'm trying to do the same thing with an IMX93. Would the solution here also apply? The register addresses are different, but I expect the principle may be much the same? There seems to be a lot more info on the IMX8 chips than the IMX9.
fTL
```c
```c
- Alex
wacampbell
Hi, I am also trying to change the serial console from UART5 to UART7.
I've tried the same steps and I'm seeing the same results.
Any updates on this?
Manuel_Salas
Hello @fTL
Could you please share your BSP version?
I need to test it by my side.
Salas.
fTL
Hello, Alejandro!
Is there a solution?
Alex
Manuel_Salas
Hello @fTL
Thank you for your patience, I am still trying to get it works, I am having the same issue as you. I am checking if the upower of ELE firmware are related to this issue.
I will let you know when I have an update.
Salas.
fTL
Hello, Alejandro!
rel_imx_6.1.55_2.2.0
Alex
fTL
Image with a default serial console (UART5) is loading without troubles.
%3CLINGO-SUB%20id%3D%22lingo-sub-1929150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1929150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20to%20all%20of%20you!%3C%2FP%3E%3CP%3EWe%20would%20like%20to%20change%20the%20default%20serial%20console%26nbsp%3Bfrom%20UART5%20to%20UART4.%20It%20is%20a%20custom%20board%20but%20very%20similar%20to%20imx8ulp-evk.%3C%2FP%3E%3CP%3EI%20changed%20several%20thing%20in%20that%20direction%3A%3C%2FP%3E%3CP%3Eimx8ulp-evk.dts%20(lpuart5%20-%26gt%3B%20lpuart4%20and%20pin%20control)%26nbsp%3B%3C%2FP%3E%3CP%3Eimx8ulp-evk-u-boot.dtsi%26nbsp%3B(lpuart5%20-%26gt%3B%20lpuart4)%3C%2FP%3E%3CP%3Eu-boot%20-%20.%5Cinclude%5Cconfigs%5Cimx8ulp_evk.h%26nbsp%3B(ttyLP1-%26gt%3BttyLP0)%3C%2FP%3E%3CP%3Elayer%20-%20%5Cmeta-freescale%5Cconf%5Cmachine%5Cinclude%5Cimx8ulp-evk.inc%20(SERIAL_CONSOLES%20%3D%20%22115200%3BttyLP1%22%20-%26gt%3B%26nbsp%3BSERIAL_CONSOLES%20%3D%20%22115200%3BttyLP0%22)%3C%2FP%3E%3CP%3Eimx-atf%20-%26nbsp%3B%5Cimx-atf%5Cplat%5Cimx%5Cimx8ulp%5Cinclude%5Cplatform_def.h%20(%23define%20IMX_LPUART_BASE%20IMX_LPUART5_BASE%20-%26gt%3B%26nbsp%3B%23define%20IMX_LPUART_BASE%20IMX_LPUART4_BASE)%3C%2FP%3E%3CP%3E%5Cconf%5Clocal.conf%20-%26nbsp%3BATF_BOOT_UART_BASE%20%3D%20%220x29390000%22%3C%2FP%3E%3CP%3EI%20have%20got%26nbsp%3B13%252%3A1%26gt%3BFail%20HID(W)%3ALIBUSB_ERROR_PIPE(8.647s)%20during%26nbsp%3Buuu%20-v%20SDPS%3A%20boot%20-scanterm%20-f%20core-image-minimal-imx8ulp-lpddr4-evk.wic.zst%2F*%20-scanlimited%200x800000%3C%2FP%3E%3CP%3EWhat%20am%20I%20missing%3F%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAlex%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I'm%20trying%20to%20do%20the%20same%20thing%20with%20an%20IMX93.%20Would%20the%20solution%20here%20also%20apply%3F%20The%20register%20addresses%20are%20different%2C%20but%20I%20expect%20the%20principle%20may%20be%20much%20the%20same%3F%20There%20seems%20to%20be%20a%20lot%20more%20info%20on%20the%20IMX8%20chips%20than%20the%20IMX9.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1948386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1948386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E**The%20Solution%20Unveiled!**%3C%2FP%3E%3CP%3ENo%20amount%20of%20forehead-flattening%20frustration%20will%20solve%20this%20task%2C%20save%20for%20relentless%20digging%20and%20perhaps%20a%20curse%20or%20two%20per%20minute...%3C%2FP%3E%3CP%3ERegardless%20of%20your%20modifications%20in%20the%20device%20tree(s)%2C%20if%20the%20PCC%20LPUART4%20Register%20(PCC_LPUART4)%20isn't%20properly%20configured%2C%20any%20attempt%20to%20write%20to%20LPUART4%20will%20throw%20an%20exception.%20This%20is%20why%20%60uuu%60%20halts%20with%20a%20LIBUSB_ERROR_PIPE%2C%20essentially%20a%20STALL%20event%20indicating%20no%20response%20from%20the%20other%20end.%3C%2FP%3E%3CP%3EBTW%20I%20enabled%20both%20UART4%20and%20UART5%20in%20the%20u-boot%20device%20tree.%3C%2FP%3E%3CP%3EWith%20invaluable%20help%20from%20a%20knowledgeable%20friend%20(thankfully%2C%20such%20expertise%20still%20exists)%2C%20we%20discovered%20that%20attempting%20to%20read%20from%20one%20of%20LPUART4's%20registers%20(%60__raw_readl(0x29390010)%3B%60)%20in%20the%20Secondary%20Program%20Loader%20(SPL)%2C%20while%20UART5%20was%20set%20as%20the%20default%20serial%20console%2C%20resulted%20in%20an%20exception%2C%20stalling%20%60uuu%60.%20The%20issue%20was%20resolved%20by%20enabling%20the%20clock%20source%20for%20LPUART4%20with%20%60__raw_writel(0xd2000000%2C%200x292D00E4)%3B%60.%3C%2FP%3E%3CP%3EAlthough%20we%20thought%20the%20issue%20was%20pinpointed%2C%20our%20investigation%20continued.%3C%2FP%3E%3CP%3EThe%20clock%20initialization%20within%20%60lpuart_serial_probe%60%20(located%20in%20%60serial_lpuart.c%60%20for%20the%20iMX8ULP%20serial%20driver)%20should%20work%20when%20CONFIG_CLK%3Dy%2C%20but%20it%20didn't%20or%20I%20missed%20something%20..%3C%2FP%3E%3CP%3EOur%20digging%20led%20us%20down%20the%20clock%20configuration%20path%20where%20we%20stumbled%20upon%20what%20might%20as%20well%20have%20been%20a%20magic%20number%3A%3C%2FP%3E%3CP%3E-%20In%20%60%2Farch%2Farm%2Finclude%2Fasm%2Farch-imx8ulp%2Fimx-regs.h%60%2C%20line%2050%3A%3CBR%20%2F%3E%60%60%60c%3CBR%20%2F%3E%23define%20LPUART_BASE%20LPUART5_RBASE%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3E-%20Similarly%2C%20this%20was%20mirrored%20in%20the%20ATF%20firmware%3A%3CBR%20%2F%3E%60%2Fplat%2Fimx%2Fimx8ulp%2Finclude%2Fplatform_def.h%60%2C%20line%2072%3A%3CBR%20%2F%3E%60%60%60c%3CBR%20%2F%3E%23define%20IMX_LPUART_BASE%20IMX_LPUART5_BASE%3CBR%20%2F%3E%60%60%60%3C%2FP%3E%3CP%3ETo%20fully%20resolve%20this%2C%20you%20must%20update%20the%20device%20trees%20(both%20the%20board%20%60.dts%60%20and%20%60*-u-boot.dtsi%60%20files)%2C%20and%20modify%20these%20two%20files%20to%20reflect%20the%20chosen%20LPUART.%20Also%2C%20ensure%20to%20review%20SPL-related%20files%20for%20any%20IO%20conflicts%20with%20your%20selected%20LPUART.%3C%2FP%3E%3CP%3EThat's%20the%20crux%20of%20it.%3C%2FP%3E%3CP%3E-%20Alex%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1939519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20am%20also%20trying%20to%20change%20the%20serial%20console%20from%20UART5%20to%20UART7.%3CBR%20%2F%3E%3CBR%20%2F%3EI've%20tried%20the%20same%20steps%20and%20I'm%20seeing%20the%20same%20results.%3C%2FP%3E%3CP%3EAny%20updates%20on%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206301%22%20target%3D%22_blank%22%3E%40fTL%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20for%20your%20patience%2C%20I%20am%20still%20trying%20to%20get%20it%20works%2C%20I%20am%20having%20the%20same%20issue%20as%20you.%20I%20am%20checking%20if%20the%20upower%20of%20ELE%20firmware%20are%20related%20to%20this%20issue.%3C%2FP%3E%0A%3CP%3EI%20will%20let%20you%20know%20when%20I%20have%20an%20update.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1936202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1936202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%2C%20Alejandro!%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20a%20solution%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EAlex%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1931756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1931756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%2C%20Alejandro!%3CBR%20%2F%3E%3CBR%20%2F%3Erel_imx_6.1.55_2.2.0%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EAlex%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1931351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1931351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206301%22%20target%3D%22_blank%22%3E%40fTL%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20your%20BSP%20version%3F%3C%2FP%3E%0A%3CP%3EI%20need%20to%20test%20it%20by%20my%20side.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1929151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX8ULP%20-%20change%20u-boot%20serial%20console%20from%20UART5%20to%20UART4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1929151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EImage%20with%20a%20default%20serial%20console%20(UART5)%20is%20loading%20without%20troubles.%3C%2FP%3E%3C%2FLINGO-BODY%3E
