I have flashed an sdcard with Yocto, Sumo, 4.14.98.
imx8qm-mek.dts is correctly filled with
&flexspi0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_flexspi0>;
status = "okay";
flash0: mt35xu512aba@0 {
even with added partitions
partition@0 {
I boot from sdcard but the kernel doesn't probe it (no messages about mt35) and of course mtd partitions are not present at all.
I would expect to see all the partitions, so to be able to write as needed; nevertheless this is not the case.
What could be the reason?
Thanks in advance & best regards,
Lorenzo
Solved! Go to Solution.
This may be caused because by SCFW configuration, it reserves the FlexSPI for use by Cortex-M4.
You'll need to rebuild your SCFW using the porting kit and remove the FlexSPI from the M4 resources, then rebuild the Linux image with the modified SCFW.
Aldo.
Aldo.
Thanks Aldo,
Properly modifying the board.c and remaking the scfw_tcm.bin, it does work indeed !
Have a nice day,
Lorenzo
