iMX8QM开发板回环测试lpuart
iMX8QM开发板回环测试lpuart
EmptyObject_
使用iMX8QM开发板回环测试lpuart,发送一次数据,但是lpuart接收那边会收到三次数据,测了好几个lpuart都是这样,是因为内核中的驱动文件fsl_lpuart.c里面的问题嘛,我用的是Android AutoMotive13.0.0_1.1.0
Sanket_Parekh
Hi @EmptyObject_
I hope you are doing well
Have you modified the driver file fsl_lpuart.c?
Please share your connection in case of loopback mode to further debug the issue.
Thanks & Regards
Sanket Parekh
EmptyObject_
@Sanket_Parekh ,I do not modify the fsl_lpuart.c,it is the original source which in the android automotive code soucres,and what do you mean share my connection of which.you replied to me just now?
