Hi all,
I have a problem setting a static IP in Android 12 with imx8mp processor.
I'm using the Ethernet app provided in the Android BSP.
When I configure the eth0 network interface with static ip,
the ipconfig.txt file is created in the /data/misc/ethernet/ipconfig.txt directory.
The file is formatted as follows:
192.168.2.162gateway192.168.2.1dns8.8.8.8ideth0eos
When I restart Android, it doesn't start, I see errors in the attached file "logcat.txt".
I also tried disabling dm-verity, but I get the same error.
Then just delete the ipconfig.txt file, and Android will restart normally with dhcp address.
Can you tell me what is the correct procedure to set a IP static in Android and make this change permanent?
Domenico Acri
can anyone help me on this problem?
Domenico Acri
Is there any news regarding my request?
Domenico Acri
Can you share which Android 12 BSP version?
thank you very much for the response.
I use Android 12.0.0_1.0.0 (Linux 5.10.72 kernel).
Domenico Acri
