Hi there,
May I have a question regarding the above processor?
We plan to run FreeRTOS on iMX6ULZ. We did find the SDK2.2 for iMX6ULL, but failed to find SDK for iMX6ULZ.
I suppose the SDK2.2_iMX6ULL_WIN is for iMXULL only. We can not use the SDK2.2_iMX6ULL_WIN to develop app (run FreeRTOS) for iMX6ULZ. Is this correct?
Jesse
解決済! 解決策の投稿を見る。
yes, this SDK is for imx6ull, imx6ulz is ultra-low-cost extension of the i.MX 6ULL family product, if you just want to check the device driver, you can refer to that SDK, and you can refer to the AN12264 to check the difference between IMX6ULL from IMX6ULZ
"https://www.nxp.com/docs/en/nxp/application-notes/AN12264.pdf"
