iMX6ULZ SDIO version
744 次查看
jupiter_hce
iMX6ULZ datasheet does not define the SDIO version supported, what is the iMX6ULZ SDIO version? Some WiFi modules use SDIO version 3, can it be supported?
Thank you.
Kind regards,
jupiter
729 次查看
jupiter_hce
Is it correct that the iMX6ULZ SDIO is a standard protocol which is able to connect to any WiFi SDIO?
If it is correct, can iMX6ULZ also connect to SDIO version 3?
Thank you very much.
Kind regards,
jh
706 次查看
Rita_Wang
Yes, you can it in the RM, The features of the uSDHC module include Compatible with the SDIO Card Specification version 3.0.
727 次查看
Rita_Wang
I will help confirm and then give you update
