I made a new board from SABRESDP_C5.
DDR3's configuration is same with SABRESDP_C5.
But, I have a big problem about DDR3.
In DDR Stress Test Tool,
Address and Data lines is generated. But SDCLK is not.
I need a help. Please advise.
Solved! Go to Solution.
Hi chillwona
probably these traces are shorted or broken, may be recommended
to check layout. Also please check Chapter 8 Avoiding Board Bring-up Problems
i.MX6 System Development User’s Guide (rev.1, 6/2013)
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
thanks.
solved.
Hi chillwona
