What's the correct PF0100 configuration to use for an iMX6 Solo? Looks like F2 or F4?
Thanks!
Solved! Go to Solution.
Hi MATT
please check MMPF0100 Datasheet Table 1. Orderable Part Variations
option for MCIMX6DL-SDP (Solo is compatible with i.MX6DL)
http://cache.freescale.com/files/analog/doc/data_sheet/MMPF0100.pdf
Great, thank you. That puts it as an F0. It's not obvious in the PF0100 document that you should use the DualLite configurations for a Solo, but that makes sense now.
The information amongst all these datasheets is really confusing. It seems as though F0 shouldn't be the correct option because it sequences SW2 later than what Table 4-1 in the IMX6SDLHDG suggests. But given that it is used in the reference design, I am happy to go with it.
Just some feedback for improved documentation. Thanks.
Hi MATT
