iMX6 SABRE AUTO audio input issues
admin
Specialist II
I'm currently trying to get audio input working with ALSA. I am working on an iMX6q SABRE AUTO running a yocto image.
The audio output works just fine.
When I record audio with arecord and play it with aplay, I don't hear anything, for example
# arecord --format=dat --duration=5 --device=hw:0,0 test
Recording WAVE 'test' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
# aplay --format=dat --duration=5 --device=hw:0,0 test
Playing WAVE 'test' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
I also tried to record and play it via gstreamer but the result didn't change.
Anyways,
Consider what output these ALSA commands show:
# arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: cs42888audio [cs42888-audio], device 0: HiFi CS42888-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: imxspdif [imx-spdif], device 0: IMX SPDIF mxc-spdif-0 []
  Subdevices: 1/1
# amixer -c 0 contents
numid=7,iface=MIXER,name='ADC High-Pass Filter Switch'
  ; type=ENUMERATED,access=rw------,values=1,items=2
  ; Item #0 'None'
  ; Item #1 'High Pass'
  : values=0
numid=18,iface=MIXER,name='ADC Single Volume Control Switch'
  ; Item #0 'Disabled'
  ; Item #1 'Enabled'
  : values=0
numid=19,iface=MIXER,name='ADC Soft Ramp and Zero Cross Control Switch'
  ; type=ENUMERATED,access=rw------,values=1,items=4
  ; Item #0 'Immediate Change'
  ; Item #1 'Zero Cross'
  ; Item #2 'Soft Ramp'
  ; Item #3 'Soft Ramp on Zero Cross'
  : values=0
numid=5,iface=MIXER,name='ADC1 Capture Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=176,step=0
  : values=128,128
  | dBscale-min=-64.00dB,step=0.50dB,mute=1
numid=12,iface=MIXER,name='ADC1 Invert Switch'
  ; type=ENUMERATED,access=rw------,values=2,items=2
  ; Item #1 'Enabled'
  : values=0,0
numid=21,iface=MIXER,name='ADC1 Single Ended Mode Switch'
  ; Item #0 'Differential'
  ; Item #1 'Single-Ended'
  : values=0
numid=6,iface=MIXER,name='ADC2 Capture Volume'
  : values=128,128
numid=13,iface=MIXER,name='ADC2 Invert Switch'
  ; Item #1 'Enabled'
  : values=0,0
numid=22,iface=MIXER,name='ADC2 Single Ended Mode Switch'
  : values=0
numid=14,iface=MIXER,name='DAC Auto Mute Switch'
  ; Item #1 'AutoMute'
  : values=0
numid=20,iface=MIXER,name='DAC Deemphasis Switch'
  ; Item #0 'No-De-Emphasis'
  ; Item #1 'De-Emphasis'
  : values=0
numid=15,iface=MIXER,name='DAC Single Volume Control Switch'
  ; Item #1 'Enabled'
  : values=0
numid=16,iface=MIXER,name='DAC Soft Ramp and Zero Cross Control Switch'
  : values=2
numid=8,iface=MIXER,name='DAC1 Invert Switch'
  ; Item #1 'Enabled'
  : values=0,0
numid=1,iface=MIXER,name='DAC1 Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=255,step=0
  : values=255,255
  | dBscale-min=-127.50dB,step=0.50dB,mute=1
numid=9,iface=MIXER,name='DAC2 Invert Switch'
  ; Item #1 'Enabled'
  : values=0,0
numid=2,iface=MIXER,name='DAC2 Playback Volume'
  : values=255,255
numid=10,iface=MIXER,name='DAC3 Invert Switch'
  ; Item #1 'Enabled'
  : values=0,0
numid=3,iface=MIXER,name='DAC3 Playback Volume'
  : values=255,255
numid=11,iface=MIXER,name='DAC4 Invert Switch'
  ; Item #1 'Enabled'
  : values=0,0
numid=4,iface=MIXER,name='DAC4 Playback Volume'
  : values=255,255
numid=17,iface=MIXER,name='Mute ADC Serial Port Switch'
  ; Item #0 'UnMute'
  ; Item #1 'Mute'
  : values=0
I don't fully understand the output here; it says that 'ADC1 Capture Volume' and 'ADC2 Capture Volume', which look like the elements responsible for audio input caputure, are muted ("dBscale-min=-64.00dB,step=0.50dB,mute=1").
At the same time 'DAC1 Playback Volume' are said to be muted too although audio output works fine.
Can anyone explain what this output means?
I searched the web for a command to unmute ADC1 and ADC2 and tried the following:
amixer -c 0 sset ADC1,0 200,200 unmute cap
  Simple mixer control 'ADC1',0
  Capabilities: cvolume
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 176
  Front Left: Capture 176 [100%] [24.00dB]
  Front Right: Capture 176 [100%] [24.00dB]
But that didn't do what I was hoping for:
  ; Item #0 'None'
  : values=0
  ; Item #1 'Enabled'
  : values=0
  : values=0
  : values=176,176
  ; Item #1 'Enabled'
  : values=0,0
  : values=0
  : values=128,128
  ; Item #1 'Enabled'
  : values=0,0
  : values=0
  : values=0
  : values=0
  ; Item #1 'Enabled'
  : values=0
  : values=2
  ; Item #1 'Enabled'
  : values=0,0
  : values=255,255
  ; Item #1 'Enabled'
  : values=0,0
  : values=255,255
  ; Item #1 'Enabled'
  : values=0,0
  : values=255,255
  ; Item #1 'Enabled'
  : values=0,0
  : values=255,255
  ; Item #0 'UnMute'
  ; Item #1 'Mute'
  : values=0
When I only try to unmute amixer doesn't event recognize the command:
# amixer -c 0 sset ADC1,0 unmute cap
amixer: Invalid command!
# amixer -c 0 sset ADC1,0mute cap
# amixer -c 0 sset ADC1,0 cap
Does anyone have an idea how to resolve this?
Thank you in advance!
Labels (2)
mustafa_ozcelik
Could you please tell others how have you been able to solve this problem, if you were able to solve it?
I have iMX8QM, also have the same problem with audio recording using CS42888. All voices are unmuted, but yet I cannot hear the recorded file, when played with aplay.
jimmychan
Please try to use alsamixer to configure capture / record parameters
