We are using imx6Q sabresd platform for our development with Linux 3.14.28_1.0.0-GA BSP but initially we used Linux 3.10.17_1.0.0-GA BSP.
We have gone through below files from Linux 3.14.28_1.0.0-GA(File-1) and Linux 3.10.17_1.0.0-GA (FIle-2) BSPs.
File-1: ~/u-boot-imx/board/freescale/mx6sabresd/mx6sabresd.c
File-2: ~/u-boot-imx/board/freescale/mx6qsabresd/mx6qsabresd.c
We could see some changes are added in File-1(compare to File-2).
In below function, we understood that the CPU frequency is lowered to 400Mhz before doing the LDO bypass and CPU frequency is increased to 800Mhz after the LDO bypass settings.
"ldo_mode_set"
In FIle-2 (Linux 3.10.17_1.0.0-GA), the below function will do the LDO bypass settings without changing the CPU frequency.
"ldo_mode_set"
We would like to know, during the LDO bypass settings why the CPU frequency is lowered in File-1(Linux 3.14.28_1.0.0-GA)? Is it recommended to do the same.?
Thank You,
Ansari
已解决! 转到解答。
Dear Igor,
by looking inside u-boot code and the commits from FSL engineer, it seems that the older implementation is a violation of datasheet power constraint
I've search for some details inside the code/datasheet and I found the some information I sent to Abdul in meta-freescale mailing list:
https://lists.yoctoproject.org/pipermail/meta-freescale/2015-April/013447.html
WDYT about that?
Kind Regards,
Andrea
Hi Abdul
CPU frequencylowering during the LDO bypass is not requirement,
but it provides less power spikes, so gives more board stability.
Dear Igor,
WDYT about that?
Kind Regards,
Andrea
