Maybe I'm getting blind but I'm not able to find the iMX283 LCDIF pinout - I mean, what's is the correspondence between (LCD_D0 ... LCD_D23) and (R0..R7/G0..G7/B0..B7) for 16/18/24 bits?
TIA,
Gonzalo.
Solved! Go to Solution.
Please take a look at section 33.2.2 (Write Datapath) of the i.MX28 Reference Manual
for details regarding pixel data from frame buffer to LCD path. Data of the frame buffer
will be mapped to external LCD bus pins.
The following is EVK approach :
LCD00 Blue 0 (LSB)
LCD07 Blue 7 (MSB)
LCD08 Green 0 (LSB)
LCD15 Green 7 (MSB)
LCD16 Red 0 (LSB)
LCD23 Red 7 (MSB)
LCD00 Blue 0 (LSB)
LCD07 Blue 7 (MSB)
LCD08 Green 0 (LSB)
LCD15 Green 7 (MSB)
LCD16 Red 0 (LSB)
LCD23 Red 7 (MSB)
Yuri, thanks for pointing the EVK approach - that has saved me a lot of time !!!!
Gonzalo.
