i.mx93. Using parallel camera and display interface in one device simultaneously.
307件の閲覧回数
Serg_mx6
Hello, I want to use i.mx93 series processor (MIMX9352CVUXMAA). I want to connect a camera to it via a parallel 8-bit interface and a display via a parallel 24-bit interface. There was a problem that the processor pins used for the display and the camera intersect (example: Pin J21 using for cam_clk and for disp_clk). Whether correctly I understand, what at the same time these two interfaces cannot be used?
Is there some way around this problem?
For example, remap display or camera pins to other pins?
2 返答(返信)
270件の閲覧回数
JorgeCas
Hello, I hope you are doing well.
The IOMUX and Pad Control Registers are able to change function of the pin and re-map them to another. For this particular case, MEDIAMIX_CAM_CLK and MEDIAMIX_DISP_CLK functions are only mapped to J21 pin.
Best regards.
50件の閲覧回数
rameshasp
Can anyone confirm still MIMX9352CVUXMAA is this part number available in NXP, Digikey, Mouser and Arrow?
