i.mx28 SPI with ref_io.1 problem!!!
1,408件の閲覧回数
grekot
Welcome.
I have a problem with support for SPI in imx287. If the clock source settings "ref_xtal", everything works perfectly. But when the clock signal as a source of law "ref_io.1", while reading the last bit is erroneous, in random bytes.
Has anyone met with this problem and how you solve it?
タグ(2)
558件の閲覧回数
JorgeRama_rezRi
May I ask how are you configuring the IO1FRAC[5:0] and DIV[8:0] bits in both cases? Do you see a change in the clock frequency when you switch from ref_xtal to ref_io1?
Best regards.
Jorge.
