i.MX8MPlus Windows 10 IoT
1,412件の閲覧回数
leven
We use i.MX8MPlus to run Windows 10 IoT system and encounter the compatibility problem of Samsung eMMC. How to solve it? Details are as follows:
1. Failed to run Windows 10 IoT using Samsung /KLMAG1JETD-B041/16GB eMMC5.1
2. Windows 10 IoT was successfully run with Samsung /KLMAG2GEUF-B04P/16GB eMMC5.1.
3. The above two Samsung eMMC burning ubuntu system runs normally, but there is a difference in running Wingdows 10 IoT.
4. The picture shows the comparison between operation failure and success.Windows OK vs  NG.png
1,405件の閲覧回数
Bio_TICFSL
There is no differences between eMMC it should works, just need erase and install the image, so far there is nothing report it.
5 返答(返信)
1,339件の閲覧回数
anthonychen-msft
Do you have the datasheets for the two Samsung parts? I'm curious what their differences might be.
Also do you have the whole video showing where the script actually fails?
1,394件の閲覧回数
leven
Hi Bio_TICFSL:
We ran Windows 10 IoT with the new Samsung /KLMAG1JETD-B041/16GB chip and still failed.
We erased the Samsung /KLMAG1JETD-B041/16GB chip and still failed to run Windows 10 IoT.
Running the following command to erase also fails :
# destroy the partition table
dd if=/dev/zero of=/dev/sdx bs=1024 count=1
995件の閲覧回数
mirkoardinghi1
I have the same problem, Do you find a solution?
232件の閲覧回数
aber
By default, it only supports emmc above 32g.
1,406件の閲覧回数
Bio_TICFSL
