Hi all, I have a question about H.264 encoder in i.MX8. According to the reference manual(Table 15-8) of i.MX8MMini, the bit rate is as below.Minimum: 10kbpsMaximum: 40 Mbps at 1080p 60 fps How about is it in i.MX8 ? Ko-hey
已解决! 转到解答。
i.MX8 QM B0 supports two HW encoders each one associated to a Cortex-M0. Each HW encoder is capable of encoding 1x H.264 1080p30 or 2x H.264 720p30.
refer to the imx8qm data sheet, for encoder, imx8QM supports up to 1080p@30,should be the 20M bps, no data for min
Hi joanxie
It's worse than i.MX8MMini. Are you sure ?
Ko-hey
