i.MX7 PCIe clock requirements
940 次查看
ulrichschmidt
Dear NXP i.MX Community,
in order pass the PCIe Gen2 compliance test for i.MX6, NXP recommends an external clock.
What about the i.MX7? Does it share the same PCIe IP? Will the internal be sufficient and what is NXP recommending?
„PCIe reference clock solution which provided by CLKx_N/P of i.MX6 chip can't pass PCIe Gen2 compliance test.  Recommend using external PCIe 2.0/3.0 clock generator with 2 HCSL outputs solution. One clock channel connect to i.MX6 as a reference input, please click Ref14 for reference circuit. Another clock channel should connect to PCIe connector, please contact generator vendor for detailed design guide.“
Uli
606 次查看
Yuri
  From Table 11 (PCIE recommendations) of "Hardware Development Guide for i.MX7Dual " :
"i.MX differential clock is not compliance with PCIe standard. NXP recommends including an external clock
source that meets the PCIe jitter specification untils the i.MX 7DS PCIe jitter compliance can be assessed."
http://www.nxp.com/assets/documents/data/en/user-guides/IMX7DSHDG.pdf
Yuri.
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
