i.MX7 DDR Rd/Wr Delay Registers
985 次查看
davidgeorge
Can anyone confirm the name of the i.MX7 PHY registers used for DDR Read and Write delay values obtained from the DDR Stress Test tool..
I suspect its DDR_PHY_OFFSET_RD_CON0 and DDR_PHY_OFFSET_WR_CON0
Thank you!
标签 (2)
标记 (1)
661 次查看
Yuri
  Correct - DDR_PHY_OFFSET_RD_CON0 and DDR_PHY_OFFSET_WR_CON0.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
662 次查看
Yuri
Yuri
