We are using rel_imx_4.1.15_2.1.0_ga version kernel.
And enable ecspi3/4 with spidev.
&ecspi3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi3>;
cs-gpios = <&gpio1 20 GPIO_ACTIVE_HIGH>;
status = "okay";
fsl,spi-num-chipselects = <1>;
spi_dev0: spi@0 {
compatible = "spidev";
spi-max-frequency = <20000000>;
reg = <0>;
status = "okay";
&ecspi4 {
pinctrl-0 = <&pinctrl_ecspi4>;
cs-gpios = <&gpio2 15 GPIO_ACTIVE_LOW>;
status = "okay";
spi_dev1: spi@0 {
reg = <0>;
status = "okay";
Then tested with latest spidev_test linux/spidev_test.c at master · torvalds/linux · GitHub
with following command line
./spidev_test -D /dev/spidev2.0 -b 32 -s 20000000 -S 1000 -I 3000
which is 32bit transfers, 20MHz clk, 1000 size, and repeat 3000 times.
and lead to error like this:
root@phyboard-segin-imx6ul-2:~# ./spidev_test -D /dev/spidev2.0 -b 32 -s 20000000 -S 1000 -I 3000
root@phyboard-segin-imx6ul-2:~# spi mode: 0x0
bits per word: 32
max speed: 20000000 Hz (20000 KHz)
[ 186.453425] spi_master spi2: I/O Error in DMA RX:3e8
can't send spi message: Connectio[ 186.459584] spi_master spi2: failed to transfer one message from queue
n timed out
but with
./spidev_test -D /dev/spidev2.0 -b 8 -s 20000000 -S 1000 -I 3000
it works:
root@phyboard-segin-imx6ul-2:~# ./spidev_test -D /dev/spidev2.0 -b 8 -s 20000000 -S 1000 -I 3000
bits per word: 8
rate: tx 6702.4kbps, rx 6702.4kbps
rate: tx 7076.8kbps, rx 7076.8kbps
rate: tx 7075.2kbps, rx 7075.2kbps
total: tx 19531.2KB, rx 19531.2KB
So 32bit transfer is not supported? Or it is spi dma which have trouble to support 32bit DMA?
thanks.
解決済! 解決策の投稿を見る。
Hi Bob
L4.1.15_2.1.0 is old kernel, since then more improvements were added
for spi-imx, for example in next L4.9.11 commits:
Hi Bob
