i.MX6SX FCB for NAND Boot.
932件の閲覧回数
satoshishimoda
Senior Contributor I
Hi community,
We have some questions about i.MX6SX NAND Boot.
Please see our questions as below.
[Q1]
Please see Figure 8-5 in IMX6SXRM Rev.0.
i.MX6SX retry if FCB is not found until Read Count becomes same value as Search Count.
Next, please see chapter 8.5.2.3.
It says "so in case the first NAND block becomes corrupted, the ROM will find its copy in the next NAND block."
So I understand FCB should be copied to all the blocks from first 4k block to n th 4k block. (n = Boot Search Count (BOOT_CFG2[4:3])).
(e.g. FCB should be copied to all the 4k blocks from 1st block to 8th block when BOOT_CFG2[4:3]=11)
Is this correct?
[Q2]
We understand MFG-Tools programs FCB and DBBT to NAND device.
Then, if the answer to Q1 is "correct", MFG-Tool should programs FCB to multiple blocks.
MFG-Tool supports it? or MFG-Tool can program FCB to only first 4k block?
Satoshi Shimoda
タグ(4)
697件の閲覧回数
igorpadykov
Hi Satoshi
1. yes this understanding is correct
2. MFG-Tool programs 4 copy of FCB
698件の閲覧回数
igorpadykov
Hi Satoshi
