Hi,Community,
I want to get some info about i.MX6SL Power Dissipation during Deep sleep and test condition such as the DDR type,size and so on.
Of cause,other info about i.MX6SL Power Dissipation during different status can be provided, I'm also glad to accept.
Thank you!
Hi 龙
you can find such data in below app note
AN4580 i.MX 6SoloLite Power Consumption Measurement
Thanks igorpadykov !
Can you help me to find some info related to the i.MX6SL boot flow especially DDR3L/LPDDR2 Load in the boot flow?
I need some Linux SW knowledge including DDR3L/LPDDR Load/usage in i.MX6SL.
Thanks igorpadykov again !
Hi 龙
I am afraid there is no data for boot case, however seems it
will be the same as in AN4580 sect.3.3.1 MP3 Audio Playback
