i.MX6DL hangs at when disabling CACHE
880件の閲覧回数
SLICE
Dear team,
My customer is facing the issue that i.MX6DualLite can hang when executing an instruction which disables CACHE after resuming from suspend mode.
This issue can occur on the customer’s board.
They found the hang-up occurs at when the following instruction was executed.
1573         /*
1574          * Restore control register but don't enable Data caches here.
1575          * Caches will be enabled after restoring MMU table entry.
1576          */
1577         ldmea         r0!, {r4}
1578         mov r11, r4
1579         ldr         r2, =CACHE_DISABLE_MASK
1580         and         r4, r4, r2
1581         mcr         p15, 0, r4, c1, c0, 0
1582         isb
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/mach-mx6/mx6_suspend.S?h=i...
The above is the source code of Android which is executed when resuming from suspended mode. And it seems to handle CACHE mode.
When i.MX6DL execute the instruction of line-1581, i.MX6DL hangs.
Could you show me why i.MX6DL can hang when manipulating CACHE mode?
And could you please show me the workaround?
Miyamoto
759件の閲覧回数
art
Dear Miyamoto,
As far as I understand, the issue is the same as discussed in the original case #00105430 in Salesforce. So, I continue working on the case there, so, further, please refer to this original case #00105430.
Also, I noticed that the customer uses very early 13.4.1 Android BSP. Ask them to try the latest Marshmallow 6.0.1_2.1.0 BSP, whose source code, pre-built images and corresponding documentation are available on the i.MX6/i.MX7 Software Center web page:
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
on their affected boards. It should improve the situation. If not, I will escalate the issue to R&D with all the details, found so far.
Artur
2 返答(返信)
760件の閲覧回数
art
Dear Miyamoto,
Artur
759件の閲覧回数
SLICE
Hello Artur,
Thanks.
Yes, this is same as case #00105430.
Miyamoto
