Hi community,
I want to confirm about JPEG encoding in i.MX6DL Android BSP.
Actually, a image taken by the camera on MCIMX6DL-SDP is whiter than a preview image.
Our environment is following.
[Board]
MCIMX6DL-SDP
[BSP]
android_jb4.2.2_1.1.0-ga
Then, please see my questions as below.
[Q1]
When JPEG encoding from camera capture on Android, is Android standard encoder used?
Or is Freescale encoder used?
[Q2]
If Freescale encoder is used, is the algorithm of Freescale encoder generic algorithm?
Or Freescale original algorithm?
Satoshi Shimoda
已解决! 转到解答。
Dear Jay Tu,
Thank you for your reply.
But sorry, I did not understand which JPEG codec is used even though I checked YuvToJpegEncoder.cpp because I'm a not software engineer.
Could you teach me what code decide JPEG codec?
Satoshi Shimoda
Hi Satoshi,
The code there encodes YUV frame to jpeg. (The real function is JpegBuilder.cpp). If you want to try other jpeg algorithm, you can have the same interface as it and changed your implementation.
Hi Jay Tu,
I understand JpegBuilder.cpp is jpeg encoder.
Then, JpegBuilder.cpp is made by freescale, so the algorithm is freescale original.
Is this correct?
Satoshi Shimoda
Hi Satoshi,
I don't know exactly if the algorithm from FSL or we just took it from Open Source, made minor modification for using here.
I think you can use the code to do some verifications if you have any concern on it like:
1. Reading YUV data from file, store it to yuv buffer
2. Using the JpegBuilding to encode yuv buffer and store to file
3. Check the output file
Hi Jay Tu,
To make sure, could you confirm which is correct to your BSP team or codec team?
Satoshi Shimoda
Hi Jay Tu,
> The original owner to the file (in MX5) already left FSL.
I understand what did you mean as following, is this correct?
"The software engineer who made this Jpeg encoder has left from FSL, so you cannot confirm the algorithm."
Satoshi Shimoda
I had updated the statement, it eventually used Android's JPEG lib.
cheers,
Jay
"Satoshi Shimoda" <admin@community.freescale.com<mailto:admin@community.freescale.com>> ? 2014/2/18 ??12:07 ???
<https://community.freescale.com/>
i.MX6DL android JPEG encoding.
reply from Satoshi Shimoda<https://community.freescale.com/people/satoshishimoda?et=watches.email.thread> in i.MX Community - View the full discussion<https://community.freescale.com/message/380881?et=watches.email.thread#380881>
Satoshi, I am not an android expert but I believe you can get some partial answer looking at the log. So boot the system, enable logcat and then take the picture. There should be many OMX logs, including the OMX components being instantiated in the task.
Dear Leonardo Standoval Gonzalez,
Can I get the answer without logcat?
I think Q1 is simple question.
And I cannot the answer of Q2 by logcat, can I?
So could you give me simple answer, Q1 -> android standard or Freescale encoder, Q2 -> generic or Freescale original algorithm?
Satoshi Shimoda
