i.MX53 QSB U-Boot tips for testing the board.
1,051 次查看
Claude_Sylvain
- When launching the i.MX53 QSB, press a key on the remote terminal to get
  into U-Boot.
- Then just enter the following command:
    - run bootcmd_obds
- This will load and execute OBDS ("On Board Diagnostic Setup"), and allow
  you to test your i.MX53 QSB board.
- Remark: This apply to the Freescale BSP.
Claude
777 次查看
Claude_Sylvain
> Is the OBDS contained in uboot somewhere?
- Probably, but I never done in depth search on "OBDS"; so
  I am not absolutely sure.
> I downloaded the OBDS source code, and need some guidance on the
> switches for the makefile.  (I'm trying to use the QSB w/the
> non-freescale PMIC).  Can you help w/this?
Sorry, but I can not help you on that point.
Claude
777 次查看
BenBeckwith
Is the OBDS contained in uboot somewhere?  I downloaded the OBDS source code, and need some guidance on the switches for the makefile.  (I'm trying to use the QSB w/the non-freescale PMIC).  Can you help w/this?
Ben
