i.MX28 - missing/more documentation - tools - elftosb/on-chip bootloader/Mdg
1,036件の閲覧回数
Jakobthomsen
hi, working with i.MX28 target…
Missing tools as arm-fsl-linux-gnueabi-objdump and arm-fsl-linux-gnueabi-readeif for disassembling of SB format? Also missing information about project when to find it…documentation for sb format? It this elftosb tools a tool from Freescale… Some more documentation for i.MX28 on-chip bootloader and Freescale’s Mfg tool will also be great.
Has build elftosb-10.12.01 BSP, trying to use sbtool… but only information man can get using sbtool…(Number after option “-x” seems to be don’t care.)
user@ubuntu:~/imx28"/ltib/rpm/BUILD/elftosb-10.12.01/bld/linux$ ./sbtool -x 2 /home/user/imx28/ltib/rootfs/boot/imx28_ivt_linux.sb
---- Boot image header ----
Signature 1:           STMP
Signature 2:           sgtl
Format version:        1.1
Flags:                 0x0001
Image blocks:          149665
First boot tag block:  9
First boot section ID: 0x00000000
Key count:             1
Key dictionary block:  7
Header blocks:         6
Section count:         1
Section header size:   1
Timestamp:             373394059000000
Product version:       999.999.999
Component version:     999.999.999
Drive tag:             0x0000
SHA-1 digest of header:
    0x00000000: e3 e5 e9 87 6c f5 f2 68 f3 26 11 6d 7d 73 05 46
    0x00000010: da 37 a2 1e
Header digest is correct.
---- Section table ----
Section 0:
    Identifier: 0x0
    Offset:     10 blocks (160 bytes)
    Length:     149653 blocks (2394448 bytes)
    Flags:      0x00000001
                0x1 = ROM_SECTION_BOOTABLE
---- Key dictionary ----
error: the image is encrypted but no key was provided
タグ(1)
605件の閲覧回数
PeterChen
When making elf to sb, you have related elf file, like vmlinux, u-boot, etc. You can use GNU tools you mentioned
to get the related contents.
