i.MX Porting Guide - Kconfig?
1,636 次查看
rjm
In i.MX Porting Guide , Rev. LF5.10.9_1.0.0, 31 March 2021, section 14.2.1, some stuff from a Buildroot environment seems to be documented.
Or am I false about this?
2 回复数
1,602 次查看
rjm
The screenshot in this PDF looks like taken from a buildroot session. But indeed: Kconfig is a concept that is used in Yocto as well. Hence I'd suggest that the accompanying text is not updated to current Yocto version or simply is too ambiguous...
1,612 次查看
Bio_TICFSL
Hello rjm,
The 5.10.9v BSP does not support buildroot, but in general that's is for adding the camera sensor to kconfig.
