I'd like to make a iMX 8M Nano IOMUX table to use when I do pin assignment in the schematic of our project.
Is there a document that has a iMX 8M Nano IOMUX table like iMX 8M MINI IOMUX table of the capture that is attached. or Should I make the table by myself?
I am looking forward to seeing your reply.
Solved! Go to Solution.
pins tool is a tool to help your on hardware design.
You can check it can help.
