i.MX 6SoloX missing NVCC_DRAM/_2P5 max currents
556 次查看
cmh
In the latest i.MX 6SoloX datasheet, the info for max supply currents of NVCC_DRAM and NVCC_DRAM_2P5 are missing. So what they will be if paring with single die LPDDR2 (800Mbps)?
Thanks!
442 次查看
igorpadykov
Hi Changming
appnote for power consumption will be released soon, so far
one can use AN4580 i.MX 6SoloLite Power Consumption and
IMX6SLCEC  max. currents as they are similar to i.MX 6SoloLite.
442 次查看
cmh
Hi igor,
Appreciated the information! Worst use case defined in the app note AN4580 is audio playback, and the combined current (MPU+memory) is 8.5mA, which is quite low. Do you have other use cases that could exercise memory more? Want to get an idea on the max current or typ current during heavy use of the memory.
Thanks!
