I have an i.MX 6SoloX and I want to use the ethernet device with the M4 core, but in the MQX and in FreeRTOS too I cannot find any ethernet driver in these SO.
Is possible to manage the ethernet device with M4?
Solved! Go to Solution.
Basically the ENET can be used with the CM4 core, please look at sections
“CM4 memory map” and “RDC Peripheral Mapping” of the i.MX6 SX RM.
But the RTOS does not support ENET.
Yuri
Yuri
