Before I perform the bitbake core-image-base I want to add openssh package so after I generate the image I am able to have ssh to the device
is
bitbake -s openssh
then
works
or
bitbake openssh
then
work?
2) Also I add package management into the build then follow this thread
https://community.nxp.com/docs/DOC-328199
but after I build the image then I perform smart command it tells me that smart command not found
anyone knows why?
Hi, Jiye Tang
Add below-mentioned lines in your conf/local.conf file to add openssh package.
You are not able to run smart command because the smart package manager is replaced by DNF package manager from Yocto Project version 2.3. You can refer section 4.11.8 in Yocto Project Reference Manual for more information.
Shivani
I build a bitbake core-image-full-cmdline
I put this in the local,conf
IMAGE_INSTALL_append += " iw wpa-supplicant net-tools ethtool
pciutils i2c-tools wireless-tools kernel-modules"
then I found out that the image I built does not have wlan0 interface only
has usb0, eth0 and lo. Did I miss anything?
On Thu, Jun 27, 2019 at 10:25 AM shivanipatel <admin@community.nxp.com>
