Hi All,
I'm using imx-4.14.98-2.0.0_ga in xwayland backend, my display is a 7" WVGA LCD, currently I found the buttons on application's title bar are too small to click, does anybody know how to change the size? I tried to set "scale=2" to weston.ini but have no effort.
B.R.
Nus
what board and bsp do you use? did you use weston? could you give more detailed information?
Hi Joan,
the board is i.MX6Q SABRESD, yocto sumo 4.14.98 and zeus 5.4.3, yes I use weston (xwayland).
you can refer to the document:
refer to the Sample Client 2 – Weston-Fullscreen
seems the link is broken
