We can build mfg images by the command mentioned in Freescale_Yocto_Project_User's_Guide / 6.2 Manufacturing Tool, MFGTool.
- Command:
$ bitbake fsl-image-mfgtool-initramfs
However, it built with mx6ull_14x14_evk_defconfig configuration, how could we build with other configuration file mx6ull_14x14_evk_nand_defconfig ?
Steven Yu
Hi Steven,
What other configuration file are mentioned to?
Have a nice day
Rita
Hi Rita,
Configuration files are in this directory
build-x11\tmp\work\imx6ull14x14evk-poky-linux-gnueabi\u-boot-imx-mfgtool\2016.03-r0\git\configs
It build with this configuration file mx6ull_14x14_evk_defconfig by default, and we would like to use this configuration file mx6ull_14x14_evk_nand_defconfig instead. However, we cannot find the entry point to change it.
Steven Yu
Hi Steven,
About the nand boot on i.MX6UL-EVK you can refer to How-To use NAND boot on i.MX6UL EVK board . Details steps you can follow.
Rita
