How does the Di trigger Dc based on some of the DI‘timers,when hsysnc vsync happened?
Look into the driver:
int32_t ipu_init_sync_panel(...)
/* Setup internal HSYNC waveform */
_ipu_di_sync_config(ipu, disp, 1, h_total - 1, DI_SYNC_CLK,
0, DI_SYNC_NONE, 0, DI_SYNC_NONE, 0, DI_SYNC_NONE,
DI_SYNC_NONE, 0, 0);
//what’s the internal HSYNC?
/* Setup active data waveform to sync with DC */
_ipu_di_sync_config(ipu, disp, 4, 0, DI_SYNC_HSYNC,
v_sync_width + v_start_width, DI_SYNC_HSYNC, height,
DI_SYNC_VSYNC, 0, DI_SYNC_NONE,
_ipu_di_sync_config(ipu, disp, 5, 0, DI_SYNC_CLK,
h_sync_width + h_start_width, DI_SYNC_CLK,
width, 4, 0, DI_SYNC_NONE, DI_SYNC_NONE, 0,0);
//Timer 4/5 is used to sync with DC? but,how? trigger DC to send data to the Di?
It seems no any explanation in the RM.
Can someboy provide the doc.
and how does the Di'pin connect with LDB,HDMI? any picture?
[Qiang]: for this code, it means the DI counter 1 was based on DI_SYNC_CLK clock (counter 0, Pixel clock), it will trigger every h_total pixel clocks, so it is a HSYNC signal, but no output from DI_PIN01.
_ipu_di_sync_config(ipu, disp, DI_SYNC_HSYNC, h_total - 1,
DI_SYNC_CLK, div * v_to_h_sync, DI_SYNC_CLK,
0, DI_SYNC_NONE, 1, DI_SYNC_NONE,
DI_SYNC_CLK, 0, h_sync_width * 2);
[Qiang]: for this code, it means DI counter 2 was based on DI_SYNC_CLK clock (counter 0, Pixel clock), it will trigger every h_total pixel clocks, so it is also HSYNC signal, but different with counter 1, it had set trigger_src and up/down, that means it will output timing signal from DI_PIN02. And the trigger clock source is counter 0 (pixel clock), so this is the real HSYNC to external display.
_ipu_di_sync_config(ipu, disp, DI_SYNC_VSYNC, v_total - 1,
DI_SYNC_INT_HSYNC, 0, DI_SYNC_NONE, 0,
DI_SYNC_INT_HSYNC, 0, v_sync_width * 2);
[Qiang] counter 3, the real VSYNC, it's clock source is internal HSYNC, counter 1.
[Qiang] this counter is the active frame counter, it will skip the vsync blanking lines, and the counter will restart when each VSYNC event triggers.
0);
[Qiang] this counter is the active line counter, it will skip the hsync blanking columes, its clock source is the pixel clock.
