how does imx7d PMIC_ON_REQ pin operate with ON/OFF pin
hyoungkikim
hi experts
I am currently designing a custom board using imx7d.
i don't understand clearly  what is the  ON/OFF pin operation. If POR_B is connected using PMIC,
when POWER ON  , does  PMIC_REQ_REQ pin   change from 0 to 1 without  ON/OFFpin pressed
I don't understand that PMIC_ON_REQ changes from 0 to 1  "by alarm" in Figure 6-5 on the manual.
thank you  sincerely
JorgeCas
As is mentioned on the image, the ONOFF pin of i.MX device shouldn't be connected.
The PWRON pin of PMIC is an input signal to the IC that generates a turn-on event. When is asserted, starts the power-on sequence.
Best regards.
