currently, OPTEE_CLIENT_SRC address change to
"https://github.com/nxp-imx/imx-optee-client.git;protocol=https"
in optee-client_3.2.0.imx.bb
but when i partial build about optee-client, build version is changed to 3.7.0
and build error is below.
ERROR: Logfile of failure stored in: /home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/temp/log.do_compile.10604
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 O=/home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/build -C /home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/git ARCH=arm64 CFG_TEE_FS_PARENT_PATH=/var/optee/tee
| make: Entering directory '/home/worker/WAVE_MAIN/build_high/tmp/work/aarch64-poky-linux/optee-client/3.7.0.imx-r0/git'
| make: *** No targets specified and no makefile found. Stop.
when i checkd optee-client_3.7.0.imx.bb, there is no especial command
# Copyright (C) 2019-2020 NXP
require optee-client.imx.inc
SRCBRANCH = "imx_5.4.3_2.0.0"
SRCREV = "bc0ec8ce1e4dc5ae23f4737ef659338b7cd408fe"
how do i fix this issue?
已解决! 转到解答。
final answer.
in the optee-client_3.2.0.imx.bb
from
OPTEE_CLIENT_SRC ?= "git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https"
SRC_URI = "${OPTEE_CLIENT_SRC};branch=${SRCBRANCH}"
to
OPTEE_CLIENT_SRC ?= "git://github.com/nxp-imx/imx-optee-client.git"
SRC_URI[md5sum]= "965bc1e91a14762841ac47007b53d5d8"
when i cleanall several times and build again, error log was changed.
bitbake -c cleanall optee-client
bitbake optee-client
error log
WARNING: optee-client-3.7.0.imx-r0 do_fetch: Renaming /home/worker/WAVE_MAIN/downloads/imx-optee-client.git to /home/worker/WAVE_MAIN/downloads/imx-optee-client.git_bad-checksum_6c979c117104742e26660040468117ce
WARNING: optee-client-3.7.0.imx-r0 do_fetch: Checksum failure encountered with download of https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0 - will attempt other sources if available
ERROR: optee-client-3.7.0.imx-r0 do_fetch: Fetcher failure for URL: 'https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0'. Checksum mismatch!
File: '/home/worker/WAVE_MAIN/downloads/imx-optee-client.git' has md5 checksum 6c979c117104742e26660040468117ce when cb0cc3102e77261d29d2d8d25fd8bee6 was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[md5sum] = "6c979c117104742e26660040468117ce"
SRC_URI[sha256sum] = "8db6329562ec41dec5e3c7fb08cd911401f3324eda241410d7b95b323ccde7b8"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
but when i add checksum in optee-client_3.7.0.imx.bb like below
SRC_URI[md5sum] = "cb0cc3102e77261d29d2d8d25fd8bee6"
it is cause of another error
ERROR: optee-client-3.7.0.imx-r0 do_fetch: Fetcher failure for URL: 'https://github.com/nxp-imx/imx-optee-client.git;protocol=https;branch=imx_5.4.3_2.0.0'. Unable to fetch URL from any source.
so i am finding the right location inserting SRC_URL checksum
as I mentioned before, how about don't change the bb file to the github, it seems couldn't get the source from this link, no matter how you delete and rebuilt the package, your bb file still the same one, so you will get the same error, I send you my bb file, and I can build it successful, pls try again
did you use original building command like
repo init -u https://source.codeaurora.org/external/imx/imx-manifest
-b imx-linux-zeus -m imx-5.4.3-2.0.0.xml
or use https://github.com/nxp-imx/imx-manifest to replace https://source.codeaurora.org/external/imx/imx-manifest ?
i changed OPTEE_CLIENT_SRC in optee-client_3.2.0.imx.bb like below
SRCBRANCH = "imx_4.14.78_1.0.0_ga"
-OPTEE_CLIENT_SRC ?= "git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https"
+OPTEE_CLIENT_SRC ?= "https://github.com/nxp-imx/imx-optee-client.git;protocol=https"
+SRC_URI[md5sum]= "965bc1e91a14762841ac47007b53d5d8"
SRCREV = "d06647d201520ac57f1331e97db6138d63bc2666"
i replace from codeaurora to github
I don't think you need change this, how about use your previous bb file?
I tested it on my side, I didn't change the bb file, when I clean this and build it again successfully
SRCBRANCH = "lf-5.15.5_1.0.0"
SRC_URI = " \
git://source.codeaurora.org/external/imx/imx-optee-client.git;protocol=https;branch=${SRCBRANCH} \
file://tee-supplicant.service \
SRCREV = "182874320395787a389e5b0f7df02b32f3c0a1b0"
my previous bb file is below
1) optee-client_3.2.0.imx.bb
# Copyright (C) 2017-2018 NXP
SUMMARY = "OPTEE Client libs"
HOMEPAGE = "http://www.optee.org/"
LICENSE = "BSD"
LIC_FILES_CHKSUM = "file://LICENSE;md5=69663ab153298557a59c67a60a743e5b"
inherit pythonnative systemd
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI_append = " file://0001-libteec-refactor-_dprintf.patch \
file://tee-supplicant.service"
S = "${WORKDIR}/git"
SYSTEMD_SERVICE_${PN} = "tee-supplicant.service"
EXTRA_OEMAKE = "CFG_SECURE_DATA_PATH=y"
2) optee-client_3.7.0.imx.bb
if you just clean optee-client and bitback optee-client again with the previous bb file, what's result you get? I know nxp source code move to github, if you built the old bsp, you need change the address from codeaurora to github the repo init, but I had a old bsp version like yours(my bb file uses codeaurora ), I clean and build again without changing bb file(I shared with you) successfully, so I ask you trying this
final answer.
from
to
