gpio
gpio
2,409 次查看
wgoodrich
For the i.mx8M:
It is possible to have a 95K pull-down on an output pad, since most pads of the i.mx8 are configured that way coming out of reset.
But in the IOMUXC_SW_PAD_CTL_PAD_xxx registers, the only option is to enable a pull-up (which I assume to be 27K).
Is that really true? Once out of reset, my only option is to enable a pull-up?
标记 (1)
4 回复数
1,888 次查看
igorpadykov
Hi Whit
out of reset pad state can not be changed and described in
Table 83. i.MX 8M Dual / 8M QuadLite / 8M Quad 17 x 17 mm functional contact assignments
i.MX8MDQ Datasheet
https://www.nxp.com/docs/en/data-sheet/IMX8MDQLQCEC.pdf
1,888 次查看
wgoodrich
Hi Igor,
Thanks for your reply! I need to re-phrase my question:
When the OS is running and is configuring the Pad control registers, how do
I enable the 90K pull-down when I am setting the other input pad
parameters. If, for example, I set up a GPIO with a Schmitt trigger input
and LVTTL in the pad control register, is the 90K pull-down still there? If
the 90K pull-down is there, how do I disable it? if it’s not there, how do
I enable it (these are the different cases I have across the design).
Thanks!
-Whit Goodrich
Izotope inc.
Sent: Thursday, August 30, 2018 5:31 PM
To: Whit Goodrich <wgoodrich@izotope.com>
Subject: Re: - Re: gpio
NXP Community
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: gpio
reply from igorpadykov
<https://community.nxp.com/people/igorpadykov?et=watches.email.thread> in *i.MX
Processors* - View the full discussion
<https://community.nxp.com/message/1052102?commentID=1052102&et=watches.email.thread#comment-1052102>
1,888 次查看
igorpadykov
Hi Whit
processor pad settings (and pull resistor) are set in dts file, as in example
    imx8mq-evk {
        pinctrl_hog: hoggrp {
            fsl,pins = &lt;
                MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16        0x19
                MX8MQ_IOMUXC_NAND_WE_B_GPIO3_IO17        0x19
fsl-imx8mq-evk.dts\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
1,888 次查看
wgoodrich
Hi Igor,
OK, I think you have answered my question in a round about way:
There is no way in software to control the state of the PULL_DOWN resistor that is present in a GPIO circuit of an IMX8M.  This differs from the operation of the imx6. In the imx8 I can program the state of the GPIO PULL_UP resistor, but not the the PULL_DOWN resistor.
Is that correct?
-Whit
