When using fw_printenv and fw_setenv, fw_env.config is a very important configuration file.
When using fw_printenv and fw_setenv, fw_env.config is a very important configuration file. Only the correct configuration of offset position and size can display and set u-boot environment variables correctly. You can modify this configuration file by the value of CONFIG_ENV_OFFSET.
Try it, please!
Have a nice day!
B.R,
Weidong
