how to add/modify files in rootfs.tar.bz2
redwill
I want to add/modify some 3rd-party files into rootfs.tar.bz2
I'd try to tar rootfs.tar.bz2,  but failed since it will broke the rootfs files.
redwill
Finally I found the error was cause by copy file between windows/linux(via samba), it makes the rootfs.tar.bz2 file broken...
It's OK now, by copy in linux shell or use uuu tool burn to board on linux
redwill
Rita_Wang
Good news it works.
Rita_Wang
Rita_Wang
Which board and bsp are you using?
redwill
board: iMx8
toolchain: fsl-imx-wayland.tar.bz2
ARCH: aarch64
rootfs: fsl-image-validation-imx
