Hello
I am using imx-android-11.0.0_2.4.0 on evk_8mq board. After entering suspend mode by button, it automatically reboots after about 1 hour. I didn`t modify any source code in original SDK.
I attached the console log when the problem is reproduced.
Could please review it and let me know what`s the problem?
Thank you.
Solved! Go to Solution.
If customer do not want to use Android 12, You can ask them to try Android 11.0.0_2.6.0 (Linux 5.10.72 kernel)https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications....
Hello b45499
I flashed image android 11.0.0_2.6.0 into evk_8mq board and the issue was not reproduced again.The issue seems to have been improved.
Thank you for your support.
Could you have a test on the newest android BSP? To see if have the same issue
Hello b45499
Hello b45499
Thank you for quickly feedback.
I have a Android 11.0.0_2.6.0 SDK but I didn`t do same test other version yet.
Could you please let me know which version?
I can find Android 12.0.0_1.0.0 on NXP portal site but my customer doesn`t want use Android 12.
