error: output DMA task timeout
976件の閲覧回数
akk1
Dear all,
i am using imx6 ul evk.
I want to use hardware asrc on imx board to convert sampling rate of decoded bit streams into one.
The input to ASRC is pcm array.
when i execute , it shows following error and did not generate any output :
fsl-asrc 2034000.asrc: Pair A: failed to process buffer: -62
kindly help me to resolve this issue.
Thanks.
3 返答(返信)
760件の閲覧回数
igorpadykov
Hi akk
seems one will have custom application for such task, refer to
sect.30.2.1 Sequence for Memory to ASRC to Memory attached Linux Manual.
Currently implemented only Sequence for Memory to ASRC to Peripheral, as
described in sect.30.2.2
760件の閲覧回数
phanikumar
Hi igor, do you know any sample code implementation of hardware asrc in imx6ul for two simultaneous conversions. For example, I want to convert 5 channels  from sampling rates 44100 Hz to 48000 Hz. Another 5 channels for 48000 Hz to 96000 Hz. As far as I know there are atmost 10 channels with three simultaneous pair conversions are possible in imx6ul. Thanks in advance.
760件の閲覧回数
JulienP
A few years after, have you resolved your issue ? I am running into the exact same one.
Julien.
