devices power management from Linux
696 次查看
angelo_d
Senior Contributor I
Hi all,
i am in a custom imx6q solution, was looking for some documentation on how to manage devices correctly from Linux, when their power is controlled (enabled/disabled) by gpio.
I suspect that doing this manually, externally from drivers (like by sysfs) could result in driver management issues after power up.
I tried also using gpio regulators but they don't seem to work as expected.
What should be the proper way to go ?
angelo
572 次查看
igorpadykov
Hi Angelo
one can check linux/Documentation/power and attached i.MX
Linux Manual low power chapters. Please follow User Guide
recommendations which modules could be powered off.
