I am using imx8mm with Kirkstone (5.15.71). I am trying to set the CPU frequency but "/sys/devices/system/cpu/cpufreq" is empty. I also try to run cpufreq-info but getting below error:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
no or unknown cpufreq driver is active on this CPU
analyzing CPU 1:
analyzing CPU 2:
analyzing CPU 3:
Can you please suggest how to set CPU frequency from userspace?
Hi @kishan_dudhatra,
One of my colleague is able to resolve the issue.
This is a workaround patch, Please check this patch at your end.
This patch will resolve your issue!
Thanks & Regards,
Himanshu Bhavani
BSP Engineer at Silicon Signals Pvt Ltd | https://siliconsignals.io/
Hello @kishan_dudhatra!
Please refer to the attached document in the section 2.5.3 CPU Frequency Scaling (CPUFREQ), there is explained how to change the CPU frequency in user space.
I hope this can help to you.
Best regards.
I refer to the documents but cpufreq is not available.
ls: cannot access '/sys/devices/system/cpu/cpu0/cpufreq': No such file or directory
My goal is to set the CPU frequency from userspace in Kirkstone and it's already worked in Zeus. I also try to enable it from driver side but did not succeed.
Can you please provide more information to enable the control to set the CPU frequency from userspace?
@ nxp team,
Could you please reply?
