connections for unused ECSPI pins
Anonymous
Deactivated User
I'm using i.MX6Solo and DualLite.
When we choose ECSPI func with MUX but don't use ECSPI pins,
can we leave unconnected them?
ECSPI_SS
ECSPI_SCLK
ECSPI_MOSI
ECSPI_MISO
For MISO pin, I think i can set Internal PU 100k.
Thanks in advance!
Labels (2)
AldoG
Yes, you're correct for both of your questions.
Aldo.
AldoG
It is not a good idea to leave digital pins left floating since it could draw power, pull-up/pull-down should be enough as you have said.
Even if you're not planning to use it at all you may disable the interface in the dts.
Aldo.
Anonymous
Deactivated User
Dear Aldo,
Thank you for your replay.
I see. Even if the pin setting is output, it's better to set pull-up/pull-down, right?
Then, if we set internal Pull-up/Pull-down setting for all pins, we can leave unconnected ECSPI pins in the hardware point of view.
Is my understanding correct?
AldoG
Aldo.
Anonymous
Deactivated User
Dear Aldo,
I got it.
Thank you so much!
